Any Ideas on this would really help?
ok about 3 months ago i went to breakfast turned car (87 eta) off and when I came out it would just crank and crank there was 35 psi on the fuel pressure gauge thats what I have it set at. but there was no spark. so I have been wanting to put on my new turbo ( old on was leaking) and change to the stage 3 clutch. so i decided just pull the engine and tranny and rebuid from ground up. well I have her all back together and same thing. while it was out I did find the tdc tab had broken off so i swapped flywheels. it is still on there but no spark. so next I thought ah obc code relay so pulled the box and while cranking I manually would trip the relay. here is where it gets wierd. ok with the relay switch circuit completed there is power to the fuel pump and it runs constantly with the ignition in run. if while imcranking with the relay on the rpm gauge doesnt work there is no spark but fuel is fine. if I trip the relay and crank, the rpm gauge starts working and the car starts until the fuel is depleted so I hot wired the fuel pumps to run tried tripping the switch and starting ran for a second then spark just cut off. aaaaaaaahhhhhhhhhh wtf is this shit.
also there is a single shielded wire that runs along the front of the valve cover it has 12v to it any ideas what that is?
and there is 2 spade connectors coming off the wire harness just outside the fire wall they are shielded I think they were for the washer fluid but cant remeber.
