89 IX Auto, recently replaced the harness
Fuel pump was not pumping so I changed it, still no good.
Checked relay, it works ok,
faked the pump out by jumping pins 30 to 87, pump works ok.
Pin 86 is putting out 12V when key is in run and start, but pin 85 is not closing to gnd or 0v, etc so the relay is not operating.
I checked my wiring and it looks like 85 goes to the ECU but I don't know what the ECU does with it.
Can anyone tell me how the ECU uses this wire? I heard somewhere that the ECU needs the crank sensor to signal before the fuel will pump. Any other states that MUST be true before that circuit will close?
Any and all help is appreciated.
Cheers
Rob
Cheers
Rob
