M20 Engine with Steel Water Journal?
  • dj01540i6sp
    • Jan 2009
    • 349
    What do I have?
    I traded a car for an Engine it is sub post to only have 78K and be an 89 - I motor???. It has an Oil Cooler attached to the lower passengers side block area and it has an ''I'' Head.
    The strange thing is it has an E Motor Water Pump and Thermostat Housing and it has this Strange Steel Water Journal cross over in front of the timing belt for the radiator hose configuration. Would some one please explain Why is this? I have never seen one of these before and would like to know why this set up is like this.
    Please Help
    Thank You
    dj
  • thereisnoyun
    • Feb 2007
    • 2301
    if you are talking about the steel hose that is behind the clutch fan... then you need to.. get a bentley. Every m20 has it.
    • dj01540i6sp
      • Jan 2009
      • 349
      Thank You!
      I appreciate your input.
      • Naplm00
        • Nov 2008
        • 1573
        every e30 except for early etas
        88 325ic ~~~> Rusty and ugly
        85 E ~~~> RIP
        • thereisnoyun
          • Feb 2007
          • 2301
          this is true, I stand corrected.
          however, I was going off the fact the original post suggested he has a 89 i motor.
          • whodwho
            • Jun 2008
            • 1547
            And another fun fact on that water pipe - have you seen the price of that pipe new... > $200.00
            My M20 Frankenbuild(s)
            4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
