if I were to rebuild a bottom end with new rod bearing, main bearing and rings.
1.) do I need to rehone the cylinders? if they look good do I just get them to clean it and keep it the way it is?
2.) does the crank need to be polished?
3.) should I balance the rod?
4.) freeze plugs?
ofcourse I want to spend as little as possible, but at hte same time I want it to be complete, but not overkill.
anyone with experience want to enlighten me on what to replace?
4.) freeze plugs?
