auxiliary fan switch!!
  • jonc39a
    • 70
    can somebody tell me what order the fan switch plugs should be in from left to right( green/black, brown/black, black ). i have a 89 325is with the 3 prong connector and it broke before i bought the car. just let me know or take a picture, so i know its the wiring and not the switch. thanks.
  • thereisnoyun
    • Feb 2007
    • 2301
    I need to know too, Im just too lazy to look at the other e30 I have. If I get to it before someone else finds it, I'll post it for ya.
    • romeomike
      • Apr 2009
      • 71
      Here you go
      The male pins are on the dual temp switch in a triangular configuration. The male connector's plastic shell has a curved edge, a flat edge, and an inwardly-notched edge.
      1
      2 3
      The curved edge is on the side of pins 1 and 2, the flat edge on pins 2 and 3, and the notched edge with pins 1 and 3.
      Pin 1 -- green/black wire
      Pin 2 -- black wire
      Pin 3 -- black/brown wire
      Last edited by romeomike; 02-18-2011, 12:16 AM. Reason: Updated pin 3 to match how it's described in the ETM
      On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
      • kalib0y
        • Dec 2004
        • 3620
        1
        2 3
        Pin 2 -- black wire
        Pin 3 -- brown/black wire
        Thread revival but I have a question
        What are the definitions of each wire?
        which one turns the fan on at the lower temperature and which one is the ground?
        thanks
        95 7.1L 16V E36 M3
        Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
        LIKE my Facebook Page! CLICK HERE
        • romeomike
          • Apr 2009
          • 71
          Hi:
          Check out page 6454-0 in the ETM for the full picture. Green/black is the power wire, black energizes the K1 normal speed relay, while black/brown energizes the K5 high speed relay. Black and black/brown ground to G200 (under the dash in the vicinity of the steering column).
          Pressing the A/C switch will also energize the K1 relay and cause the aux fan to turn at its lower speed.
          Adios for now,
          RM
