Does anybody have a picture of a the fuel filter installed. I'm replacing my gas tank which I removed about 4mts ago along w/ all the fuel lines and misplaced my notes F**&&%$$K. Any info would be appreciated.
Fuel Filter/Gas Tank hose routing
Tags: None
That car should have the 63L tank with only the in-tank fuel pump. In which case the fuel supply is via the hard line that runs across the top of the tank which goes to the filter and then to the hard line that runs forward to the fuel rail. The return hard line from the front of the car goes to the return fitting in the side of the tank. The plastic line across the top of the tank routes forward to the charcoal cannister.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
