OEM or Mishimoto Radiator?
  • brian52555
    • 425
    Yes, I have searched-
    I'm wondering how easy it is to install/use a Mishimoto radiator with an early (87 325iS) car. I know it's possible with the later models, but I haven't seen anything written on installing it with the 87s and older cars. No DIY FAQs, etc.
    Is it a huge pain to install? If so I'll probably just go with an OEM... cheaper and direct installation.
    Thanks
  • thereisnoyun
    • Feb 2007
    • 2301
    you need late model plumbing. Its not that bad, just need coolant overflow tank from 88+ and different hoses to come off the thermostat. Other than that it shouldnt be a issue.
    • jasapp
      • 67
      I've been wondering the same thing. I'm just finishing up an S52 swap, and I'd really like to run the e36 Mishimoto. The measurements on their web site say it's 27.7" wide. I've got a euro '85 323i, and if I measure my frame, it's just barely 27" across.
      Can someone verify how wide their Mishimoto is? A measurement across the frame would also be nice.
      Thanks,
      ~jeff
      • Wishno87
        • 6025
        Do they not make an early model radiator?
        • Miasma
          • Apr 2007
          • 2009
          I think he is talking about the E36 ones, They are pretty much identical to a late model one.
          An ideal upgrade for the brittle stock BMW radiator, the Mishimoto E30/E36 Performance Aluminum Radiator provides your vehicle with enhanced reliability and improved cooling efficiency. BMWs are known to have frequent cooling-related failures due to the use of numerous plastic components throughout the system. A simple coolant leak can result in overheating, accelerated engine wear, or head gasket failure. Whether you have a daily-driven E36 M3 or an M20 spinning a large turbocharger, this E30 and E36 radiator provides ideal temperatures on and off the track. Most people overlook the importance of installing an upgraded radiator in their vehicle. Along with providing increased coolant capacity, this BMW radiator improves heat dissipation, which is beneficial for both stock and modified applications.The Mishimoto E30/E36 Performance Aluminum Radiator is manufactured using durable aircraft-quality aluminum end tanks, precision TIG-welded to an efficient brazed aluminum core. The inlet and outlets provide precise leak-free connections, and all factory overflow and temperature sensor ports are present on the Mishimoto E30 and E36 radiator for use with stock sensors and hoses. This BMW radiator also includes a M12 x 1.5 Magnetic Oil Drain Plug with Dowty seal, which effectively removes metal fragments circulating in the cooling system. The Mishimoto BMW Performance Aluminum Radiator incorporates mounting points for the factory external automatic transmission cooler, and it is a direct bolt-on fit for all 6-cylinder E30/E36 models from 1988 to 1991. As with all our BMW parts, this aluminum BMW radiator includes the Mishimoto Lifetime Warranty, ensuring superior product quality and craftsmanship.
          • jasapp
            • 67
            That's correct. Sorry if I wasn't clear.
            This is the radiator I'm interested in:
            Does anyone have measurements?
            Thanks,
            ~jeff
            • lifeiskaos
              • 1709
              it'll fit just fine in the car, but i wouldnt do it if i were you... the inlet and outlet are on different sides in early/late models. even if you do get hoses that fit, it was designed with the inlet/outlet switched, and might not work as well
