Is there any problems with shoving an 885 head on an eta block fitted with an i crank/pistons? I don't remember if theres oil differences between i and eta.
i head on eta block with i internals ?
You will actually have better thrust bearings and 360 degree oiling grooves using the eta block (much better than the later "i" block)...but be sure if new bearings are ordered make sure they are for the eta block if you are changing them for new ones...
2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbs
