Okay I'm getting ready to put an I cam and Valve springs into my supereta head (along with all the other I goodies for a cheap stroker).
I greatly suspect this will be impossible without removing the head, right?
Anyways, while I'm doing it I'm also replacing the following:
Timing belt/tensioner
Head Gasket
Valve Cover Gasket
Cam Seal
Head Bolts
Etc. Etc.
My question is should I be replacing any little parts in the head at the same time? Like valve stem seals, valve guides or keepers?
As is my engine has 170k on it and runs flawlessly. I had the vavle cover off recently and nothing showed any obvious excessive wear. (Everything actually looked better than I expected)
Thanks in advance guys.
Head Gasket
Valve Cover Gasket
Cam Seal
Head Bolts
Etc. Etc.
