The saga continues...lots of white smoke.
  • danalyse
    • Apr 2009
    • 153
    Bought a cabrio with known rough running issues from out of state. When delivered it limped home from a nearby drop off. Could not start at all once home but discovered that the crank sensor wire was resting on the alternator and perhaps fraying a bit. Once removed from that position car started up. PO was able to get the OBD to readout but I am not. His read out was injectors. He cleaned them and he said it ran better for a while then it started running rough again. I replaced the injectors with some rebuilt 19lb models which made the car run significantly better but now I am getting a large amount of white smoke? Does the CPU need to be reaclimated to the new injectors. What about the fuel pressure regulator. I am lost for the moment and any advice will be appreciated.
  • Devil Inc
    • Jan 2008
    • 802
    Umm...white smoke is generally related to a head gasket issue. Check the oil for traces of coolant.
    • danalyse
      • Apr 2009
      • 153
      The saga continued
      I discovered that the oil was overfilled by about a quart so I drained off a quart and the oil looked uncontaminated.
      • Devil Inc
        • Jan 2008
        • 802
        Check the coolant overflow tank to see if there is any funkiness floating around in there. I wouldn't rule out a head issue, could be just a blown coolant passage, so it's only burning coolant.
        • danalyse
          • Apr 2009
          • 153
          More of the continuing saga
          The white smoke comes and goes. Do not see any yuk in the overflow but it is rather low so cant see much. Does not seem to be an inordinate pressure build up in the overflow tank. The car is chugging and idling a bit rough. Will a compression test reveal coolant leakage into the cylinders. I wish I could get the check engine light to go off as I cannot get the OBD system to work. Incidentally, what are those green rectangular lights on the dash just above the steering column light.
          • Devil Inc
            • Jan 2008
            • 802
            Those are your service indicator lights. They'll go to an amber color when it feels you need an oil change and various other things. The coming and going of the smoke could indicate a cracked head, where it would while it was cold and once it warmed up it would seal and no longer produce the white smoke. Mine did that when I bought it.
            • danalyse
              • Apr 2009
              • 153
              White smoke again
              Ugh. I did replace the injectors. What is the FRP. do you think a compression will reveal the problem.
              • Devil Inc
                • Jan 2008
                • 802
                Sorry wrong thread, I fixed.
                • thereisnoyun
                  • Feb 2007
                  • 2301
                  fuel pressure regulator (FRP) its connected on the fuel rain in the end with teh two hoses going into it.
                  If its internal to the combustion, yes, if yo uare running really rought and puffing white smoke yes. But even if it does determine the compression is low, it coudl still be a variety of issue. It could be a crackhead, crack block, bent valve. The list goes on.
                  for a rough/ bad running engine. I would just pull it and do a top end clean up and replace the head gasket and all the intake gasket.
                  • g323
                    • Dec 2008
                    • 6
                    Dude, use K&W Block sealant quick. Also remove the valve cover and make sure nothings snapped or broken up there.
                    E21 1982 323i
                    Under the Hood:
                    M20B23 with 731 Head, Dogleg tranny
                    • RangerGress
                      • 91
                      A leakdown test will tell you if there is a cylinder sealing problem and which cylinder it is. You should also be able to identify if it's coolant related because you can usually hear where the air is going. There is a leakdown DIY on my website at the bottom of the track tales page.
                      Based on the leakdown test, you can determine whether it makes sense to remove the head. If you do remove the head, you might as well have a valve job done on it before you put the head back on.
                      www.Gress.org
                      All that is necessary for the triumph of evil, is for good men to do nothing. -E. Burke
                      NASA SpecE30 #6, BMWCCA #161
