Help! Still blowing lots of white smoke.
  • danalyse
    • Apr 2009
    • 153
    Bought a E30 several weeks ago with problems. First it did not want to run but now it is running well. Began to blow lots of white smelly smoke only after 10 or so minutes of running. The consensus was head gasket. I did a gasket job, had the valves ground, replaced water pump, timing belt, and the exhaust guides. Car started right up and runs well but the smoke is back and perhaps never went away. Did a compression test before the valvee job and had good compression. I need ideas.
  • themitchster359
    • 654
    you torque down the head bolts to spec, used new ones??
    89 Alpine White e30 325i
    • danalyse
      • Apr 2009
      • 153
      Still blowing smoke.
      Yes and Yes.
      • romeomike
        • Apr 2009
        • 71
        When you had the valves ground, did anyone check the head for leaks/cracks?
        On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
        • danalyse
          • Apr 2009
          • 153
          Had the head work done by an established shop and I assume they did that.
          • bmwpower
            • 1556
            Never assume. Do a pressure test on the coolant system. Check oil for coolant. When its blowing smoke grab coolant hoses. Are they hard?
            89 325is track project / 05 x5 / 99 M3
            E30 stuff for sale | Parts I'm looking for
            • danalyse
              • Apr 2009
              • 153
              I wish I did see coolant in the oil or oil in the coolant but I do not.
              • danalyse
                • Apr 2009
                • 153
                Could it be a an excessive rich mixture as a result of ecu or sensor issues?
                • bmwpower
                  • 1556
                  Could be...maybe. Check that the right sensors are in the right place.
                  • danalyse
                    • Apr 2009
                    • 153
                    Which ones.
                    • bmwpower
                      • 1556
                      Which ones.
                      The coolant temp sensor in particular. If it's disconnected or on the wrong harness, it will cause it to run rich.
                      • danalyse
                        • Apr 2009
                        • 153
                        There two sensors right next to each other in the thermostat housing. The prior owner had been screwing around with the injectors and perhaps he switched them.
