Well, upon completion of putting my car back together it will not start...
I jumped the fuel pump relay and it turns the fuel pump on when the car is off. I checked all the relays in another car and they all work fine.
My other issue is that I am not getting spark, besides one small spark when I turn the key. The coil pack was tested and works on another car, the wires are all good, grounds seem to be all good (we used electrical cables to add more ground-age).
The ECU has been changed out with three different ones, and all three slightly buzz when the key is turned.
The motor does have an m30 AFM and throttle body/tps... If that may have anything to do with this problem. I did plug in the stock AFM, with no difference made.
Ideas would be much appreciated!
__________________
__________________
