My 1989 325 I engine the dust and I have a 1986 325 E engine that I bought in a parts car.
I've tried to find info about the swap but I keep running into info about building stroker motors and most posts are about swapping the I head onto an E block.
Is the swap of the E motor to an I car pretty straight forward or do I need to swap out the head and intake off of my existing I motor to the E block to use my existing wiring harness and computer?
Will the 5 speed trans hook up to the E block with no problems? The E car is an automatic and my I car is a 5 speed, will the I flywheel bolt up to the E block?
Are the motor mounts the same in the 86 E and 89 I cars?
Thanks for any help you can give me
