Help figure WTF wrong
  • Johnny Redline
    • Aug 2009
    • 27
    BLAH so another problem has poked it's ugly head with my 85 m20. I go to start the [COLOR=blue ! important][COLOR=blue ! important]car[/color][/color] after putting on newer control arms from an 88 and axle, intake manifold gasket, thermostat housing gasket, and cold start valve and it doesn't even flinch......
    All power works when I turn the key but when i go to start it the [COLOR=blue ! important][COLOR=blue ! important]fuel [COLOR=blue ! important]pump[/color][/color][/color] starts spraying and there is no starter turning. All the car does is just sit there and run the fuel pump that sounds like its just spraying into an abyss.
    here is a video of what i'm talking about.
  • Aptyp
    • 6584
    make sure your sensors on transmission bellhousing are plugged in correctly.
    • dreamchasin
      • 3892
      How do you know which one goes where? On the swap i just did there is no specific one that shows it has to go in a specific place.
      90 325is alpine2 m50b25 becoming a dorifto car.
