M20B20 unburnt fuel smell
  • cro320
    • 147
    My M20B20 smells from exhaust, very bad also on high revs it puff black smoke!
    apart this runs smooth, idle is perfect, pull pretty good, and doesn't make any problems but this smell of fuel is annoying.
    Any tips what to check?
    Thanks
  • 884door
    • Nov 2008
    • 380
    Thanks
    o2 sensor, spark plugs, wires, air filter, probably a combination of all of them.
    • ADEN
      • 620
      i have this started 2 days ago and i suspect my plugs gonna change them today
      • cro320
        • 147
        everything except O2 sensor is brand new, car is regulary serviced, o2 sensor was checked and tester says it's fine.
        Any more ideas?
        • SpecM
          • Oct 2005
          • 4531
          coolant temp sensor maybe?
          what year? is a Jetronic, Motronic 1.0, 1.3?
          1989 cirrisblau-metallic 325i
          • cro320
            • 147
            1990, bosch motronic 1.0
            my friend checked blue temp sensor with ohmmeter, readings are fine
            maybe cat is out of order?
            • ADEN
              • 620
              do you have a performance chip installed?
              • cro320
                • 147
                no chip.
                standard engine, M20B20, 95kw
                • ADEN
                  • 620
                  checked your FPR? leaking, smelling?
                  • bcrdukes
                    • 107
                    Is it hard to start when cold?
                    1989 E30 BMW 325i
                    1998 E36 BMW M3
                    2004 E46 BMW 325i
                    • Smatt90IS
                      • 151
                      leaking injectors?
                      • ethree
                        • Aug 2007
                        • 1216
                        Do you guys have smog equipment?
                        • 884door
                          • Nov 2008
                          • 380
                          check the fuel line right where it connects to the back of the fuel rail, mine rotted out there and didn't really leak but it smelled horrid.
