Ok so i know its only when its running. ITs dripping of the front right corner of the oil pan and its wet on up the motor. But i cant see far enough to know whats leaking? cam seal maybe?
Narrowing down oil loss.
Tags: None
Cam seal, valve cover gaskets, or oil filter and/or adapter. You may have to get the car up in the air, clean of all the oil, and watch for the first sign of the leak to localize the source.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
^+1
Sounds like a cam seal or filter housing o-ring to me if it leaks enough to show while running. VC oil usually burns off on the exhaust heat shields and manifolds, but it could definitely be leaking ahead of the manifolds. Rocker plugs should definitely be changed as well-- they get rock hard and let a ton of oil past, but usually just major seepage.
But yeah, basically the cam seal, valve cover gasket, rocker plugs, and the oil filter + housing are all likely suspects.Comment
the front and rear of the cylinder head, they are square on one end and round on the other. Black in colour, rubber in material.
-camComment
