bought this car and owner said that the transmission is going out that it grinds going into 2nd and 3rd.
when you drive it all gears are perfect except for 2nd and 3rd they grind going into gear if you push the shifter hard into the gear and keep pressure on the shifter while you let out of the clutch then it pops then its in gear and is fine, no grinding no nothing its perfect once its in gear. the only time it really grinds is if you dont leave pressure on the shifter while going into gear then it will grind until you push the clutch back in like its not all the way into the gear.
the shifter also has alot of slop in it
does this sound like the linkage needs to be rebuilt or do you guys think its a internal tranny issue?
thanks in advance
Dustin
thanks in advance
Dustin
