advice on cleaning shortblock before head install
  • guibo09
    • Dec 2008
    • 834
    here's the situation:
    - head has been off for about 1 year
    - oil fouling spray sprayed on cylinder walls, pistons, head bolt holes, etc
    - covered with plastic/sheets
    - oil still in the pan
    - alot of sanding, sand blasting, cleaning, body work etc in the engine bay over the year
    - there is surely some media, dirt, grime and other crap that has made its way onto the shortblock
    - still need to clean the block mating surface, more potential crap falling into engine
    what should i do to clean out the shortblock before installing the head? just spray brake cleaner everywhere + compressed air? im afraid that some particles have fallen into the oil feed passage and will be pumped straight into the head at first start up. i figure whatever has fallen down into the pan will get filtered before getting pumped into the engine.
    any advice?
    90 E30 325i
  • Naplm00
    • Nov 2008
    • 1573
    you can maybe remove the pan drain bolt and flush the engine with clean oil or diesel fuel allowing all the crap to just drain out the bottom.
    flush=pour oil or diesel all over exposed parts and oil passeges/galleys and them let it all drain out
    88 325ic ~~~> Rusty and ugly
    85 E ~~~> RIP
    • guibo09
      • Dec 2008
      • 834
      will the crap flow back through the oil pump into the pan and out, or will it accumulate at the pump?
      90 E30 325i
      • lennon
        • Jun 2008
        • 1416
        lol that wont work very well. motors shouldnt be left open and exposed to things that will hurt them like OP describes.
