Stripped Dowel pin
  • E30Inspired
    • 86
    Stripped Dowel pin
    The other day I was replacing the Distributor and I notice # 2 and the area around it was stripped. So the timing must be off. Iv notice a loss of throttle response.
    Does any one have any ideas?
    Will I need to just replace the camshaft?
    Thanks,
  • smonkbmw
    Professor
    • Jun 2006
    • 4549
    um, why would you "notice" it was stripped? you don't need to take that much apart to replace the distributor. did you put the rotor on backwards? lol
    • Knockenwelle
      • Jul 2008
      • 395
      Yes. You will need a new cam, sprocket, and pin. New rockers will also be needed on the new cam lobes. The only reason that would ever happen is if the cam bolt was loose. The head needs to come off to change the cam, but that will also give you a chance to make sure you had no V-P contact. In fact, with the head off and cam out, you might as well just go for a full rebuild, including new valve seals and a valve job. Sucks, but be happy it didn't let go entirely.
      Mike
      '91 325i track car. Mostly...
      • E30Inspired
        • 86
        In fact I didn't put it on backwards I was just cleaning up the engine and say it was stripped.
        • E30Inspired
          • 86
          Would it just be a good idea to just swap to a M20B25?
          My eta motor has over 310k on it.
          • Brian 89 325i
            • 1450
            Probably a great idea to make a hybrid motor if you have to rebuild anyway.
            Get yourself some custom pistons or work a 731 head and motronic 1.3.
            Good thing you saw it before the pin really took a shit.
            • SiGmA_X
              • Mar 2006
              • 287
              Am I wrong in guessing that you cannot see the keyway with the cam sprocket bolt installed? I'm pretty sure I'm correct.
              :wgaf:
              PNW BMW Crew ///
              '93 325iS
              '99 528iT
