I have an '87 325is that cuts out at any speed. It will do that for just an instant most of the time but it is bad enough to make it undrivable. Almost everything has been replaced by me or the previous owner. Last night I noticed that the tach would drop to zero when the engine would cut out. I took an oscilloscope and monitored almost every input and output to the DME. When the engine would die, the signals to the injector, the coil, and the tach would go away, usually for well less than a second. This, to me, would indicate the DME or the crank position sensor. The previous owner replaced the DME and I also bought a second DME, which has the same symptoms. The crank position sensor meters 550 ohms and the signal to the DME does not drop out when the engine dies. I inspected the various grounds that I could find and they look fine. I monitored the input power to the DME and that did not drop when the engined died.
I had also replaced the ICV and checked the intake for vacuum leaks and I think all that is good. Of course, the loss of injector and spark signal would make it seem to not be a vacuum problem.
Any ideas?
Thanks, Doug
Any ideas?
Thanks, Doug
