Safe Rev Limits and Valve Float?
  • DmcL
    • Apr 2009
    • 260
    just a quickie here.. whats the safe upper limit of RPM for standard type rockers? i have replaced all 12 about 7-8 months ago so none are old. would 7500rpm be a realistic goal? would 7500rpm be of any benefit with stock head/cam and merely intake/exhaust? (logic here is that with my 4.10 diff i cant hit 60 in 2nd so if i can up the limit to allow 60 in 2nd it will drop my times).
    regarding valve float.. would i need to worry about that at 7500rpm or below?
    Currently E30-less
    - EthosMotorsports.com
  • ben312
    • Jan 2009
    • 1139
    Mark D chip.
    Originally posted by Beej '86 325es
    every time an M-tech 1 spoiler is destroyed, a baby seal dies.
    Originally posted by Jparkr
    The last thing we need are more of the retards on here thinking they are engineers too.
    87 325:83 jetta coupe:99 volvo c70:99 volvo s70
    • DmcL
      • Apr 2009
      • 260
      already have 4 different chips atm. have tunerpro just need a burner and ill be doing my own. was not asking about a chip asking about the physical engine speed.
      Currently E30-less
      • Erick
        Official R3V Drifter
        • 11169
        Stick to 6500 on M20s. Rockers are the engine's weakest link.
        ..::Support FullOpp::..
        FullOpp Stickers for sale!
        Feedback Thread
        • Dirtbleed
          • 495
          After a dyno run, max hp was at 5500rpm and max torque at 5000rpm. No need to rev it to 7500rpm.
          • iX-treame
            • 440
            I was just talking to my friend John about it the m20 can turn higher speeds you just need better rockers and you can turn close to 8k
            '88 325iX -Totaled
            '97 M3 - Sold
            '85 euro e30 Pete McHenry 2.8L m20 Stroker - Parting out
            '89 325is - Sold
            '95 540i 6spd
            '87 325is M Technic I s50
              With a stock head, the optimal shift point(as determined by the torque curve) for an M20B25 will be around 6100rpm. The engine will rev past that, but for optimal performance you want to stay in meat of the torque curve. A search for "optimal shift points" will be illuminating.
              To answer the OP's question, the weak point on an M20B25 head is the rockers. Billet rockers are usually safe for a 7000rpm redline, but might be iffy above that.
              • craz azn
                • 749
                I run my car regularly up to 7000, with a stock cam and stock rockers, but the powerband is clearly not up there anymore. It is only useful for AutoX. As far as powerband goes, after 6k it drops off, and 6500+ its just making noise. When I am on track with my car, I just shift at 6k. No sense to labor it.
                I personally would not rev it above 7200 on stock valvetrain.
                Rippin' Proper | Youtube | Vimeo |
                • craz azn
                  • 749
                  Originally posted by jlevie
                  with a stock head, the optimal shift point(as determined by the torque curve) for an m20b25 will be around 6100rpm. The engine will rev past that, but for optimal performance you want to stay in meat of the torque curve. A search for "optimal shift points" will be illuminating.
                  +1
                  • DmcL
                    • Apr 2009
                    • 260
                    know about shift points and all that.. just thinkint the ability to rev that little higher would be a good thing. was on a 6850rpm chip but couldnt crack 60 in 2nd with the 4.10 have a 7000rpm chip in now tho havent tried 60/2nd yet so may be a mute point but still curious.
                    Currently E30-less
                      Unless you are in a situation where an up shift to third would be immediately followed by a down shift to second, times would be improved by shifting up. If you can't shift up, run a lower final drive ratio.
                      • xwill112x
                        • Jan 2009
                        • 4236
                        you should be able to get 60mph in second.
                        my m42 is chipped with a dinan and limits out a 7k, and i snatch 3rd right at 60 or so.
                        • DmcL
                          • Apr 2009
                          • 260
                          well then i might be ok with the current 7k chip. with a 6850rpm chip i was topping 2nd just shy of 60 which makes my 0-60 times look bad. was thinking a little more revs up top would mean better times from a dig.. well on paper anyway. if i can crack 60 in 2nd my 0-60 time should drop a good bit as its the extra gearchange that causes the 7.5 time otherwise prob be more like 6-ish. dont want a taller geared diff because that will lessen the power put to the ground in each gear. i retained the 4.10 for better acceleration so i dont want to ditch it.
                          car does 7.5 to 60 BUT thats including having to change to 3rd to hit 60. i can manage 2.1 60ft times too and thats on old all weather tyres that came on the weaves when i go them.. so old the sidewalls have small cracks in them so id imagine the compound has gone hard. be interesting to see my 60ft times with some sticky rubber in the back.
                          Currently E30-less
                          • Farbin Kaiber
                            Lil' Puppet
                            • 29502
                            Moot point, moot point.
                            • SpecM
                              • Oct 2005
                              • 4531
                              m42 cars had a different tranny with slightly different ratios, so that too is a "moot" point
                              1989 cirrisblau-metallic 325i
