Ok I know there are 200 different post about 2.7i strokers...
But none of them with WHP numbers....
My mechanic is building 2 strockers for 2 different cars... One is a stock E bottom end with an I head and all electronics, Jim Comforti chip, 17.5lbs inyectors, IE short tube headers with 2.5 exhaust without cat to a magnaflow muffler, MSD 6al.
Anu idea on the approximate WHP???
The second one is a 2.7e block cut 3mm with E crank and E rods with I pistons...Schrick 284 cam, MSD 6al, BavAuto long tube Headers with 2.5 Exhaust with magnaflow cat, resonator and magnaflow muffler and stock I ecu.With all i electronics. Stock I injectors...
Any ideas on the WHP???
Also which setup do you guys think works better and safer???
Thanks
Thanks
