I came home two nights ago, then tried to start it the following morning but it wouldn't start. It would just keep cranking and cranking. I've replaced the following with known good parts: m20 afm, spark plug wires, ignition coil, and distributor cap and rotor. It's getting fuel. Timing belt is 1yr 8 months old. WTFFFF. Any ideas?
When I crank it and I leave the oil cap open, I can see the cam doing it's business..as in, it's turning and turning.
EDIT: I've also been trying to use the search function for the past two days to look around for similar issues, but the search function isn't working for me.
