I snapped some rockers and got a used head off a r3v user and put new rockers and a new shaft in it, and got new top side gasket set and put everything in today and fired it up and had some smoke coming from the exhaust mani and it looks like its just from the new gasket/ heat shields. is this common? i cant see any leaks from the head..
Also the water jacket on the throttle body is leaking like a bastard cause i didnt get a new gasket for the piece that the 2 coolant lines hook up, so i tried using rtv and its still pissing out, can i just loop the lines and not have any bad consequences? it seems like it just heats the pcv hose, or is it meant to heat all the intake air?
thoughts?
thoughts?
