So I purchased a head and upon opening the package, I noticed 1 bent intake stud and another snapped flush with the head. I made a claim with fedex and was wondering what are my options as far as repairing such a thing. Any real advice would be appreciated.
Broken intake studs
Have a machine shop remove the snapped off stud. Thats what I would do.RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
Welcome e30 (brilliantrot '90 325is) 12/23/06
DaveCN = Old Man
My signature picture was taken by ME! Not by anyone else!
Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down.Comment
Im the guy at the machine shop If you dont have a bridgeport style milling machine and a cylinder head roll over fixture dont try it the factory bottoms them out sometimes and years of corosion dosnt help either you can try the easy out dont drill deeper than any of the other holes wrap tape around the drill as a depth stop and if it comes out easy consider your self lucky it takes 20 to 30 minutes with the milling machine cause you can alighn the drill easy and use larger and larger drill bits(controlled feed rate)untill you can pull the threads out like a coil (years of expeience you'll be able to do the same thing with a hand drill if its on the work bench)Comment
Well, I ended up buying some cheap extractors from northern tool and turns out the metal on that was softer then the stud. So I'm going to attempt with some better quality stuff and if I cant handle it, I'm taking it to a machine shop.Originally posted by StereoInstaller1Do you feel like something is trying to penetrate your butthole?Comment
