head rebuild cost?
  • e30loverSC
    • 575
    head rebuild cost?
    I have a head with a broken rocker. I just want to take it somewhere to be inspeceted and fix it anything is wrong. I have new seals that came with the head gasket set. And im hoping they will put them in. About how will this cost you think?
  • Hallen
    • 1008
    If you just have them replace the rocker, replace the valve stem seals, and do a leak check, probably less than $200. If you have them do more then it will cost more.
    1987 E30 325is
    1999 E46 323i
    RIP 1994 E32 740iL
    oo=[][]=oo
    • Jean
      • 18228
      200-300 at the bare minimum before doing anything else. I would look for recommendations on local shops that know bmw heads and call them for estimates.
      I had m10 head taken apart, resurfaced and re-assembled with new guides only and it was about $350 total. This was as simple as it gets and gets expensive quick ;)
      • e30loverSC
        • 575
        Well im getting it totally redone 300 even !
        • lennon
          • Jun 2008
          • 1416
          what does 'totally redone' include?
          • e30loverSC
            • 575
            all new seals, resurfacing, valve guides, hot tank, "valve job"... cam resurface
            • thereisnoyun
              • Feb 2007
              • 2301
              Originally posted by e30loversc
              all new seals, resurfacing, valve guides, hot tank, "valve job"... Cam resurface
              800
