FML how to change the fuel tank
  • IminDiegoTriick
    • Oct 2009
    • 1564
    So.. yesterday i was traveling southbound on the freeway @ 3 in the morning with very dense fog. I hear a thump and see sparks flying on the freeway, i pull over to the left shoulder and i see my gasoline pouring out like no tomorrow. I got towed and took a look at what happend in the morning, and there was a hole the size of a quarter in the fuel tank. I have no idea what I hit but the first process in fixing this, is to figure what to do now. How do I find another fuel tank, how to install it? PLease & thank you
    Fast life fuck slow..Low life for life
    Let the mix flow..Let the night flow
    I'm so gone ✗ ♥ O
  • JTapper
    • Sep 2009
    • 847
    Sparks + Fuel = No good!
    Get yourself a Bentley manual, I lent mine out, otherwise I would scan those pages and send them to you.
    A Bentley is the best money you will ever spend on your E30.
    Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
    • IminDiegoTriick
      • Oct 2009
      • 1564
      Yeah I got the RB manual & scanned it and found no trace on installation :(
      I'm so gone ✗ ♥ O
        Changing the tank is pretty straight forward. Remove the exhaust and drive shaft, disconnect the electricals and hoses from the tank, remove the bolts that hold the tank up and it will drop right out. You will need the car well up in the air on four jack stands or a lift for this job.
        • IminDiegoTriick
          • Oct 2009
          • 1564
          okay thank you jlevie will do this when I pick up an extra from the junkie yard. much appreciated
          I'm so gone ✗ ♥ O
          • Jean
            • 18228
            Most tanks at the pick and pull yards have holes in them ...it's fucking stupid..they punch a hole to drain the gas.
            It's not a complicated job, but it sure isn't fun. If you were closer I would sell you my clean 89 tank for cheap.
            • jeffw
              • 1087
              i think i have an extra fuel tank if you need it. let me know
              • IminDiegoTriick
                • Oct 2009
                • 1564
                Dang both your offers sound great.. I will try & find a great conditioned 88-91 fuel tank from the junkie yard first and if I have no luck I shall PM you :)
                I'm so gone ✗ ♥ O
                • jeffw
                  • 1087
                  ok that works
