Which DME Should I Be Using?
  • bcrdukes
    • 107
    I have an 89 325i - North American, stock motor, 5-speed.
    It has a 173 DME and the vehicle's production date is 10/88. Should it be using the 173 or 380 DME?
    1989 E30 BMW 325i
    1998 E36 BMW M3
    2004 E46 BMW 325i
  • Red88
    • Nov 2008
    • 1161
    173 came with the car. Stick with it.
    Have you made a purchase from www.blunttech.com recently?
    sigpic<< wrecked
    • bcrdukes
      • 107
      I read somewhere that there are other DMEs for this production year and that the 173 was a bad DME.
      1989 E30 BMW 325i
      1998 E36 BMW M3
      2004 E46 BMW 325i
      • Red88
        • Nov 2008
        • 1161
        The 153 DME was considered the "bad" one out of the two (153 in earlier models, 173 in later ones) ever offered in a 325i. I believe the 153 is Motronic 1.1 where 173 is 1.3, and the 173 results in a smoother idle and will throw far more codes when stomp tested.
        sigpic<< wrecked
          Essentially correct. A 173 or later is required for the stomp test to produce diagnostic codes.
            • 37833
            173 is said to be the best option for the 2.5 based M20 engine.
            Grover Beach, California
            BimmerHeads.com
            • T Verdier
              • Aug 2007
              • 2636
              I have an 87 325IS and i replaced my DME with a 173 from this guy ^^^
              and it is a smoother idle.
