89 i engine, just started a knocking sound toward the front exhaust side down low but goes away above 1500. Stethoscope on the block or head reveals no knocking sounds just valve clicking. My only guess is an exhaust leak but the gaskets are new(1000 mi), or something wrong with the A/C compressor pulley. Anyone experience this?
Knock, goes away when revved, WTF?
It is easy enough to prove/disprove the A/C compressor as being the cause by removing its belt. If the noise is still present with the A/C belt off, check the harmonic balancer for signs of delamination or looseness.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
John
2013 NASA-SE TTE Champion
Tracks driven: AMP, Barber, CMP, CMS (Lowe's), Daytona, NCCAR, Road Atlanta, Rockingham, RRR, Sebring, Texas World Speedway, VIR (Full, Grand, South, North, & Patriot), Watkins Glen.Comment
TKS for responses but the car is an auto. Haven't had time to check it out yet. My friend brought his e34 530 and I did the front brakes, spark plugs, K&N air filter, belts, coolant and oil change, and replaced both fog lights. I had no desire to work on my own stuff."Life is hard...it's a lot harder if you're stupid."
Tom
72 2002
87 327i
88 525i
88 535i
03 530iComment
[IMG]http://www.r3vlimited.com/board/
