m2 leaking 5w20
  • blocke
    • 1305
    m2 leaking 5w20
    Anyone running 5w-20 mobile 1 run into the problem of oil seeping past the oil drain plug? I just switched to 5-w20 and after i got all the oil into the car, it started seeping past the oil drain plug at about 1 drop every 30 seconds.
    What gives?
    Parts Wanted
    The Never-ending Resto Mod
  • PeaveyBassist
    • Sep 2004
    • 3511
    You need a new crush washer. Or it isnt tight enough...
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
    • RickSloan
      • 2401
      5w 20???
      20w 50 my friend
      Need Illustration or Design work? www.robbiebyerly.com
      • kamotors
        • Nov 2007
        • 7102
        mine leaks their even with new bolt/washer and 20w50, I ended up wrapping the drain bolt in thread tape and its been working for about 1 year.
        7speedshop.com
        • blocke
          • 1305
          5w 20???
          20w 50 my friend
          sorry thats what I meant..fit of dislexia
          Parts Wanted
          • lennon
            • Jun 2008
            • 1416
            try a new bolt and new washer. that should fix the leak.
              5w20 is way too thin for San Diego. You should be using 20w50.
              • blocke
                • 1305
                Got it fixed. It was a new washer, so I figured that wouldnt be it. But I drained out the oil, replaced washer with another, and put teflon tape around threads for good measure. Filled it back up with oil and no more drips.
                And to clarify: i am using 20w50, the 5w20 thing was typo.
                Parts Wanted
