Parasitic draw... need input
    :hitler: Sorry, had to use it.
    So before i start, I have installed a Motronic 1.3 M20B25 into an e21 323i and I have one last problem I need solved before I can call the swap successful. I am having a hell of a time figuring out why a fully charged battery it losing all of its charge when left overnight.
    I have a Brand new Deka that I relocated into the trunk and have a wire running to a post on the engine bay that powers all four of the wires found on the 325is harness.
    When I hook up a charger to supplement a fully charged battery which is the only way the engine will fire, the injectors will come on intermittently until finally the engine catches and starts. When the engine idles, it is smooth for about thirty seconds and then developes a stumble at idle which is uncharacteristic of an M20.
    I know there is a short somewhere, I need to know how to go about finding it and where to start. My friend recommended pulling each fuse and seeing which one cause the draw to stop with an ammeter on the battery. I checked draw on the battery with ignition and everything off and the draw was 0.063.
    If anyone has another method or could point me in the right direction, it would be much appreciated, thanks.
    I have used this procedure many times before. you will need a test light.
    Hope this helps.
    http://www.r3vlimited.com/board/show...45#post1801045
    Went ahead a pasted this from another site to ours. Cheers.
      If you are measuring 63ma as the parasitic draw, that isn't your problem.
      Is the charger required to get the car to crank, or to get the engine to fire? If the former, I'd wonder is there may be a bad ground between the block and chassis. If the later, it sounds like there may be a problem with the power or grounds to the DME. The following may be helpful.
      For the engine to run the following conditions must be met:
      Power on DME pins:
      27 Start Input
      18 Un-switched Power input
      37 Power Input from Main Relay
      Ground on DME pins 2, 14, 19, 24
      Timing data from the CPS on DME pins 47 & 48 from a rotating engine
      To have spark power must be present at the coil positive and ground pulses
      from the DME's pin 1 must reach the coil negative. Power to the coil is
      controlled by the ignition switch via C101. When checking for spark, use the
      output lead from the coil to eliminate the distributor, rotor and plug wires.
      To have injector firing power must be present at each injector and ground
      pulses from the DME's pin 16 (Bank1) and pin 17 (Bank2) must reach the
      respective injector bank. Note that the injectors are wired as two banks of
      three. With cylinder 1,3,5 being bank 1 and 2,4,6 being bank 2. Power to the
      injectors is controlled by the main relay.
      The fuel pump relay must have power on pin 86 (relay coil) from the main relay
      output (pin 87) and power on pin 30. The DME will ground pin 85 to turn on the
      relay and power the pump(s) via pin 87. Of the above, only the fuel pump power
      is fused. So if the there's power at pin 87, but not at the pump, check fuse
      11.
      The main relay and DME pin 18 receive power from the smaller of the to wires
      that connect to the battery's positive terminal. That wire incorporates an
      in-line fuse. When the DME is presented with a start signal, it grounds the
      main relay pin 85 and furnishes power to the fuel pump relay, injectors, and
      DME.
      Troubleshooting:
      Disconnect the battery and the DME cable. Then:
      1) Disconnect the coil negative and check continuity from that connector to
      DME pin 1. Also verify that from DME pin 1 to ground is an open circuit.
      2) Check the resistance across DME 47 & 47, which should be 500-560
      ohms. If the CPS is dismounted, the resistance can be seen to change
      from about 500 to 540-540 when a ferrous object is brought to the face of the
      sensor. Neither pin should be grounded.
      3) Check for continuity from DME 36 to main relay 85 and from DME 3 to fuel
      pump relay 85.
      Reconnect the coil, remount the CPS (air gap should be 0.040"), plug the
      relays back in, reconnect the DME, and connect the battery. Then do the
      following checks:
      1) With the key off, verify that power is present at DME pin 18 and main relay
      86 & 30.
      2) With the key on, verify that power is present at DME pin 27 and pin
      18. Power to pin 18 is from the main relay and there should be power to the
      injectors and fuel pump relay.
      3) With the key on, verify that no voltage is present at the DME grounds (2,
      14, 19, 24).
      4) Verify that power is present at the coil positive and at fuel pump relay
      pin 30. Those get switched power from the ignition switch via C101.
      The engine will start and run (if poorly) with only those connections to the
      DME in place. The other signals from Cylinder ID, AFM, temp sensor, etc., are
      necessary for proper operation. But they won't prevent the engine from firing.
      IMPORTANT:
      A power check means seeing a voltage within about a tenth of a volt of what
      you measure across the batter terminals, which should be at least 12.6v on a
      charged battery.
      A continuity check means seeing less that 1 ohm of resistance.
      An open circuit means seeing a resistance of at least 100k ohms.
      A good quality auto-ranging Digital Multimeter will make these tests much
      easier.
      But then it is possible that you don't have an electrical problem at all and the following may be helpful.
      Idle or hard starting problems are most commonly caused by intake leaks and/or
      a sticky or defective Idle Control Valve (ICV). The only reliable method of
      locating intake leaks is to have a smoke test run on the intake and crank case
      and to test the brake booster with a gage and vacuum pump. The complete list
      of possible causes of an intake leak is:
      Intake boot
      Throttle body gasket
      ICV hoses & connections
      Brake booster, hoses, and connections
      Crank case breather hose
      Evaporative control hose and valve
      Fuel pressure regulator & hose
      Injector seals
      Valve cover gaskets & bungs
      Oil filler cap
      Dip stick o-rings
      Oil return tube o-rings
      While leaks in some of those can be found by inspection or by spraying carb
      cleaner on suspect areas, not finding leaks that way doesn't eliminate the
      possibility. Only a smoke test will really work.
      Once the possibility of intake leaks is eliminated, the ICV needs to be
      removed and cleaned with carb cleaner until the vane inside moves freely. When
      the ignition is switched on you should be able to feel vibration from the
      ICV. If no vibration the ICV is bad, there's a problem with its wiring or
      connector, there's a problem with the TPS, or the DME (or Idle Control Module
      (ICM) on an ETA car) is faulty.
      For the DME (or ICM) to control idle, the idle switch in the TPS must work
      correctly. The switch should close when the throttle stop is 0.020-0.060" off
      the idle stop screw.
      The fuel system should be tested via the suite of tests in the Bentley manual
      as invalid rail pressure can be a contributor to idle and starting problems. A
      simple injector check is to pull the injectors, jumper the fuel relay to run
      the pump, and see if the injectors are leaking. You can also point the
      injectors into a towel, remove the coil wire, and crank the engine to see if
      all of the injectors appear to be spraying in a similar fashion. The best
      approach to possible injector problems is to have the injectors cleaned and
      flow tested. Since raw fuel can or will be released in these tests, have a
      fire extinguisher handy.
      The O2 sensor can be a contributor to idle problems. The O2 sensor is a
      scheduled maintenance item with a useful life of no more than 100k. If the
      sensor has that mileage or more (or is of unknown age), replace it.
      The AFM can be a contributor. If the vane doesn't move freely or the
      resistance track is worn the DME may be receiving invalid data from the
      AFM. And if someone has fiddled with the bypass air adjustment the DME may be
      unable to stabilize idle. The bypass air adjustment should only be adjusted
      per the procedure in the Bentley and with an exhaust gas analyzer. And even
      then everything else associated with engine management has to first be
      operating properly. If the AFM becomes a suspect, replacement with a good used
      unit is the best approach.
      Improperly adjusted or malfunctioning valves will affect idle and starting. As
      can compression issues from ring or cylinder wear. A valve adjustment is
      called for every 15k. A useful diagnostic is to run compression and leak down
      tests on the engine. And aged ignition wires, plugs, distributor cap, or
      rotor can cause problems. Insulation does break down with time and heat. And
      since the youngest E30 is going on 19 years old, if the ignition system is
      original or the plugs are old replacement is indicated.
      Although not usually a problem, a bad DME temp sensor is a possibility. That
      generally won't cause an unstable idle, but can cause hard cold or hard hot
      starts and/or a rough idle. As can problems with the timing reference sensors.
      When all other possibilities have been eliminated and idle or starting
      problems persist, replacement of the DME, or if applicable the ICM, is
      indicated.
        ^ holy crap, can we get a sticky on that?
        that info will solve 95% of all no start and/or driveability issues
        1989 cirrisblau-metallic 325i
          Tried starting to find this problem today. I started from the most simple procedure before diving into the procedures posted above. What I did was bridge the battery from the negative side and set the ammeter to 20m and got a reading of 0.12. I then went about disconnecting fuses and checked the meter after each one, every time it read 0.12.
          I went through disconnecting everything except the battery cable and once all auxilery cables were removed, then only did the meter read zero. If anything is connected to the post, no matter what it is, I get draw. I first thought it was coming solely from the power wire I have run from the battery to red power wires coming off of the harness on the passenger side, but it was not. Anything that is connected to the post causes a draw according to the meter. I may also have a bad meter and or not be doing this correctly I don't have a lot of experience in solving electrical problems . I will have a buddy help me go through the very nice page posted up by J.Levie, thank you, but right now it is just basics. I appreciate any ideas and criticism. Thanks
            Right now, I think jlevie is the most helpful person on this board. I know he has helped me a ton with my issue already.
