Seized engine need some advice
  • Intro
    • Apr 2008
    • 196
    So my engine has 22XXXX miles on it, and I was coming home for the holidays, and pretty sure my engine seized on me. I had just gotten off a twisty portion where I had tapped fuel cut, and then was merging into traffic, where i started to accelerate and it starting whining really loud, coming from the engine. so i pull off the side of the road, it is still running, shut it off. Then call a tow truck. They come and pick it up, I check the rockers (hoping it was them cause that would be a snap), not the rockers, check spark plugs, no signs of anything. Try to start it, no go. Pretty sure the engine is messed up, cylinder head looks to be in good shape.
    So what are my options? I have about 800$ i can use to fix this thing. The head/intake/oilpan/ stuff is all good. I was thinking of pulling the engine and confirming it is Fawked, and then begin the repair process. Only have a month before school starts, so I would like to be done with this asap. Possibly a running 2.7l swap?
    What would you guys do?
  • barry
    • 1642
    Motor
    You obviously need to find out the motor problem and then make a decision, m20's are easy to rebuild. I have a rebuilt 2.7 LMK
    Good Luck
    Barry
    • lennon
      • Jun 2008
      • 1416
      figure out whats wrong with the motor, you obviously have no clue yet
      • Intro
        • Apr 2008
        • 196
        where would i start? I have ruled out rocker arms, which I was hoping it was. when the engine starting making the noise the oil light came on (on the dash). Next thing im gonna do is check the starter. Then what?
        • Dozyproductions
          • Jan 2007
          • 4682
          fix the problem with a m50 ;)
          • dashboardmonkey
            FUCK YOUR WAFFLES
            • Jun 2008
            • 6158
            Originally posted by Intro
            where would i start? when the engine starting making the noise the oil light came on (on the dash).
            start by tearing the whole motor apart, oil light is usually a bad sign
            -Andy
            • Adrian_Visser
              • Jun 2006
              • 2823
              So if you're checking the starter I assume that it doesn't even turn over correct? You must have really been tossing that shit around to have bad enough oil starvation to actually seize the engine though. jeez
              '89 Alpine S52 with goodies
              • Intro
                • Apr 2008
                • 196
                Yay it doesn't even try to turn over. It was a long trip and I was just getting into town on a road i knew, tapped fuel cut, then came to a stop. Then merging onto a busy street started accelerating and it let go. Luckily had the gf with me who had AAA. I need to get that, saved my ass a few times.
                • StereoInstaller1
                  GAS
                  • 22679
                  Hey, I have an idea...TELL US WHAT FUCKING CAR YOU HAVE!!!!!
                  and...you kids get off my lawn.
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • lennon
                    • Jun 2008
                    • 1416
                    if the oil light came on you probably lost oil pressure. maybe your oil pump failed. is this an m20?
                    Last edited by lennon; 12-24-2009, 02:52 PM. Reason: removing arrogant asshole comment
                    • Adrian_Visser
                      • Jun 2006
                      • 2823
                      So no clicking from the starter solenoid even? you should at least hear it engaging.
                      • lennon
                        • Jun 2008
                        • 1416
                        what do you mean "it let go"? in your original post you said it started whining and you shut it off. which is it?
                        • She loved E
                          • Aug 2007
                          • 363
                          turn signal fluid. 99% chance that's it, as its connected directly to the rocker arms.
                          M119 M42 M62 S52 S62
                          • ben312
                            • Jan 2009
                            • 1139
                            No no. Its not even turning over, it must be the johnson rod.
                            Originally posted by Beej '86 325es
                            every time an M-tech 1 spoiler is destroyed, a baby seal dies.
                            Originally posted by Jparkr
                            The last thing we need are more of the retards on here thinking they are engineers too.
                            87 325:83 jetta coupe:99 volvo c70:99 volvo s70
                            • Adrian_Visser
                              • Jun 2006
                              • 2823
                              Yeah OP I think it's time for some better info on what happened.
