hey gus im having some serious problems with the e30. it doesnt want to go into gear. also when its in reverse its acting like its grabbing. i know its not the shifter i have already cheked that. maybe the throw out bearing is done or mabe the slave cylinder. also the abs light came on the other day but now its off agin. it just started doing this a few days ago when i drove it from wv back to ohio. any help would be good thanks guy
87 325 problems
Tags: None
That could be a problem with the clutch hydraulics, or a worn out clutch. If the clutch pedal feels normal and there are no leaks at the slave or lines a failing master cylinder is possible. If not that, then you need a new clutch.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
thanks ill take a look at it after the 15in of snow melt. lol i think the clutch is shot i jnow the throw out bearing is making the nastiest noise ever. i was just trying to make it through the winter. oh wellComment
guys bad news i was on the way back home last night when the car started bucking in 5th and then it felt like the clutch started to slip but i trield another gear and i lost 1st 2nd 3rd and 5th so i had to limp the car 40 miles only useing 4th. im perty sure that the tranny is shot. any one else have an idea?Comment
Shifter fork? Just get a new tranny.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard.Comment
