Aftermarket Tach?
  • Luis325
    • 3847
    Aftermarket Tach?
    Anyone know how can i connect an aftermarket tach?
    Where can i connect my signal wire and my positive and ground??
    Thanks!
    1986 "C2 2.7 Alpina" Sedan
    1987 325ic Black Vert
    Pick up the tach signal from the wire that supplies said signal to the cluster. Switched power is available from one of the "accessory" fuses next to the fuse box (the other is unswitched). Or you could pick up power from one of the switched supplies to the cluster. Ground can be had in a lot of places, one of which being the main ground point above the steering column.
    • Luis325
      • 3847
      Originally posted by jlevie
      Pick up the tach signal from the wire that supplies said signal to the cluster..
      Do you know which wire it its? Color??
      Im still learning on the e30's.....
      Thanks!
      • MattM
        • Apr 2009
        • 931
        only black wire comming from C1(blue plug on back of cluster) its usually got a shrink wrap like stuff over it.
        Full Build Thread Here
          • 37828
          Ok, I'll be the one to ask... WHY?
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • Wh33lhop
            • 11705
            I'll second that.
            paint sucks
            • xwill112x
              • Jan 2009
              • 4236
              maybe he has tarboz and turns 10k
              • Luis325
                • 3847
                Cause Its a race car and I have this...
                And want to run my Tac in the middle......
                • george graves
                  • 19996
                  Fuhl raze?
                  (just messin' with ya)
                  Originally posted by Matt-B
