I did that too!
"holy shit, everything is broken! oh....wrong table"
Anyway, did everything else check out ok?
Have you checked for fuel?
If you have fuel pressure and the injectors are opening and closing (listen for clicking individually with a stethoscope) and everything else is good, I may recommend finding some way to heat the ECU to about 90 degrees and seeing if it starts then.
That will test if it's bad/worn out transistors causing your no-spark issue.
