gotta head job, slight shudder
  • bmw325csi
    • May 2007
    • 4045
    Was driving the other night and my temp began climbing, pulled over to check the coolant, I opened the res cap and the car started dumping out what looked like milkshake. Any who, my mechanic took the engine apart, the gasket seemed fine but got changed anyway.The head was sent out to get a compression test and a valve job. I also got new hoses, thermostat, radiator, and the thing the distributer rotor goes on to (cant remember what its called).
    The car runs like a champ but when I stop at a stop light, after a second it develops a shake, I can feel the whole engine shaking but once I drive it goes away. I tried searching and found a post by George Graves talking about engine misfire but nothing solid.
    Any help is appriciated guys, I just spent 1300 bucks and I cant stand this. I plan on taking it back to the mechanic but wanted to get as much info about it as I can, I cant afford another penny atm.
    harry/harout
  • PeaveyBassist
    • Sep 2004
    • 3511
    If you got a head job that was done correctly, you should be getting a very large shudder. It is normal.
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      Idle control valve installed backwards?
      • bmw325csi
        • May 2007
        • 4045
        idle doesn't move though
        BTW the guy did mention I had a slight leak in the throttle body attachment which he siliconed
        harry/harout
        • IRON-E
          • 16548
          That was my first guess now I'm dying to read what everyone else's input is.
          @IRON-E30 aka Edwin:D
          • bmw325csi
            • May 2007
            • 4045
            can you elaborate?
            harry/harout
            • gtdragon980
              • Jun 2008
              • 1808
              Correct me if I'm wrong, but I think what he means is that since it's running strong again, it's causing the engine to shudder more at idle because the compression is higher. For some reason the speed the engine spins at idle makes you feel the engine at its most unbalanced state. Similar to how when you drive at speeds around 55 and 60mph, you can feel the wheels at their most unbalanced state. That's just my guess lol
              FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
              Originally posted by scabzzzz
              I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
              1989 325i - Project/weekend driver
              2002 325i - DD
              2005 Suzuki SV650 - Toy
              • mightywhitey
                • Oct 2009
                • 985
                Originally posted by bmw325csi
                can you elaborate?
                I believe he is referring to a busted nut after a properly performed head job.
                1991 e30 328i M52 swapped: Gone
                1995 e34 540i/6 1 of 76 Clean
                1985 e28 euro 525i the daily
                • PeaveyBassist
                  • Sep 2004
                  • 3511
                  EDIT: ^^^Yes! hahaha
                  Maybe I'm the only perverted one here?
                  DaveCN = Old Man
                  • gtdragon980
                    • Jun 2008
                    • 1808
                    hahaha noice! I'm feeling pretty slow right about now! :drink:
                    2002 325i - DD
                      It sounds to me like there may be a small intake leak.
                      • Atreus
                        • 1846
                        vacuum leak? i forgot my v/c gasket, (duh) and it ran the same way, for the whole 2 minutes.. lol.
                        1991 325iC - Mauritsblau sumthin metallic blue. DEAD
                        1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
                        1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
                        1991 325iC - Calypsorot Metallic
                        1994 540i - Granitsilber
                        I've had blunts cock in my mouth, but I'm not gay.
                        • browntown
                          • Jun 2004
                          • 3524
                          vacuum leak or bad idle would be my first guesses
                          • bmw325csi
                            • May 2007
                            • 4045
                            ha ha Peavey, thought you were serious for a second. Thanks for the input guys, checking said things now
                            harry/harout
                            • E-Thirty
                              • 1331
                              Out of curiousity, did you ever find what was causing the shudder?
                              Do you feel like something is trying to penetrate your butthole?
