Ive heard story's of oil on the K&N filters getting sucked into the engine and gumming stuff up. Is this true, or are these filters fine? Should I stick with paper filters?
K&N filters ok to use?
Put them in all the time no issues. If you follow proper instructions on oiling.sigpic
Levent
%20levent@gutenparts.com
Ladies:
1998 E36 m3/4/5 1988 325i 1989 325iT -
Oiled air filters are a problem on a car with an MAF as oil from the filter can contaminate the thin film anemometer in the MAF. An E30 uses a vane type air flow meter and thus isn't affected by oil from the filter.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
From what I understand, the issue is with the MAF sensor wire getting oil on it. And like ZM said, Just re-oil them properly when you do (follow instructions, dont go overboard on the oil etc. )
In the case of an M20, there is no MAF sensor to gunk up.
EDIT ^^^^ jlevie and I replied at the same timeComment
