wont rev passed 5500 when warm
  • Smatt90IS
    • 151
    car runs great for 10 minutes then it runs perfect up untill 5500ish then the power falls on its face recently replaced o2 plugs plug wires cap rotor fpr. i think its either my fuel pump or the ecu temp sensor or my dinan chip is screwed up the car pulls great on the down low and before it gets warm any suggestions would be apreciated o and i gave it a compression test which was perfect
  • Smatt90IS
    • 151
    it doesnt cut out or spudder it just quits reving up
    • PeaveyBassist
      • Sep 2004
      • 3511
      Check a couple of things.
      Air flow meter
      Crank sensor
      If you have your stock chip, put that back in and see if it makes a difference too.
      RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
      Welcome e30 (brilliantrot '90 325is) 12/23/06
      DaveCN = Old Man
      My signature picture was taken by ME! Not by anyone else!
      If people keep quoting me in their sig, I'm going to burn this motherfucker down.
      • Smatt90IS
        • 151
        k wheres the crank sensor and my maf is good i unplugged it while the car was running and it ran way worse
          Check the operation of the WOT switch in the TPS. It sounds like yours isn't working.
          • Smatt90IS
            • 151
            okay its kind of lacking in the mid range to but if its not on the WOT on the TPS the maps probly fucked which i think it is cause it only does this bs at WOT thanks any other ideas would be greatly appreciated
            • xwill112x
              • Jan 2009
              • 4237
              cap and rotor? always check those if a m20 is running like shit.
              • Smatt90IS
                • 151
                cleaned c101 connector and put some dielectrical grease car runs perfect! took it on some curvey roads for an hour and beat the shit out of it and it did not cut out or hesitate at all times like these remind me why i love the old e30 haha
                • xwill112x
                  • Jan 2009
                  • 4237
                  better hope that timing belt doesn't snap!
                  • Smatt90IS
                    • 151
                    its fresh
