M20 stall for a moment than pulls off?
  • cro320
    • 147
    I just watched this video and mine M20 doest the same!
    When I release the clutch, car goes but stalls a little then pulls away...is this common?
    Common causes of hesitation coming off idle are intake leaks and a worn resistance track in the AFM. The only sure way of locating all intake leaks is to have smoke test run. The easiest way of diagnosing and AFM issue is to swap in a known good unit.
    • 87-325ic
      • Apr 2006
      • 1198
      the resistance tracks can be fixed too! a slight bend in the sweep arm to put it on fresh material..
