wtf idle problems.... please help
  • norcalE30
    • Dec 2008
    • 932
    So the other day i bought some CRC maf cleaner and used it to clean out my throttle body, maf, and idle control valve and now the damn thing wont idle... When I start it up it idles around 1100 for a while then fluctuates from about 800-1200. Everything feels normal when driving, it just wont idle... This is my dd so any help is appreciated
    Originally posted by kronus
    pff, all of you are slow as hell anyway. Eta > all
  • 5KWattson
    • Apr 2009
    • 809
    double check connections and if they are all good check your IAC valve it maybe stuck(closed or open) cant remember which way right now
    "God created turbo lag to give V8's a chance" Taylor D.
    • norcalE30
      • Dec 2008
      • 932
      thats what the shop said... he said something about it spinning tho... when i unplug the iac rev's shoot up to like 3000 then back down to about 2000
        My first suspicion would be that you have one or more intake leaks. The only sure way of finding intake leaks is to have a smoke test run on the intake.
        • norcalE30
          • Dec 2008
          • 932
          the thought had run across my mind... using maf cleaner wouldnt create an intake leak tho....
            The MAF cleaner wouldn't cause a leak, but what you have to do to be able to clean with it could.
            • norcalE30
              • Dec 2008
              • 932
              But i didnt remove anything besides the airbox and the intake boot.... both got reinstalled properly. Im thinking i fubar'd the IAC
              • 87-325ic
                • Apr 2006
                • 1198
                did you clean it out really well? make sure everything is plugged back in. if its surging up and down. i would really look at the ICV again.
                • norcalE30
                  • Dec 2008
                  • 932
                  wow crisis averted... simple ICV swap did the trick
                  • Ruffian
                    • 378
                    Good to hear. I was worried you had cracked your intake boot.
                    Keith
                    "Die feine Art, schnell zu sein."
                    "I don't have a gambling problem, my gambling pays for my e30 addiction."
