Last night my starter started giving me trouble. It consistently will turn the motor over once or twice and then it sounds like the starter gear is disengaging from the flywheel.
I took this video this morning. The last time I try starting it in the video, right about the 19 second mark, I keep the key engaged in the starting position and you can hear what sounds like the starter gear re-engage with the flywheel. If I keep the key engaged in general I can hear what sounds like the starter gear whirring.
Things I know:
I haven't had time yet to dig into things and check for obvious stuff like loose connections etc. Any thoughts on where I should start troubleshooting?
Thanks in advance!
Things I know:
- battery is very new and puts out ~13.5 volts at rest
- alternator is one month old and puts out anywhere from 13.8-14.4 volts while car is running
- car runs tip top once it is started
- starter worked fine until last night and no changes have been made
Thanks in advance!
