My e30 decided to act up tonight. It has been driving perfectly fine since I've had it and up until I parked it earlier, everything was fine. When I left the place I was at, the motor turned over, but it struggled to stay on, my thought was its either a vacuum issue or fuel pump.
After testing everything else, I decided to bang on the fuel pump cover and sure enough, the car started right up and I drove home 7 miles, no issue.
Now, I'm the type to fix something before it goes wrong/bad. I'm trying to figure out if the problem I had tonight is related to the fuel pump or fuel pump relay. How does one distinguish b/w the two? Can a relay fix the issue or do you think I should jump straight to replacing the fuel pump.
You 2 cents is highly appreciated...
