idle, but no idle?
  • E30_(1st Musk)_
    • 2008
    idle, but no idle?
    my problem is this.
    i can hear the car idle. and my idel control valve makes noise as if air were leaking out...
    but on my cluster the rpm's stay and dosent bounce up and down...??
  • 2.5-12
    • Jan 2010
    • 1814
    the tachometer isn't sensitive enough to show a rough idle
    1991 E30 M3 Brilliant/black - S54B32/5M
    1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
    2011 E82 1M VO/blk/6M
    1991 E31 850i red/grey/6M
    1997 F355 spider red/tan/6M
    • SpecM
      • Oct 2005
      • 4531
      m20s tend to idle a bit rough anyway, at least all of mine have
      if the speed isn't bouncing too much and it isn't shaking the car apart, there's not much you can do
      1989 cirrisblau-metallic 325i
      • E30_(1st Musk)_
        • 2008
        Well I know how my dads car idles.and its not ur avrge m20 idle..ill just keep checking for ripped hoses and change the control valve
        • E30_(1st Musk)_
          • 2008
          I managed to find out that it wasnt the control valve...
          but now it idles at 2k and stays there.:hitler:
          over 40 views...someone has to have an idea. come on guys
          • lennon
            • Jun 2008
            • 1416
            my first guess would be vacuum leaks. start replacing hoses. what did you do to make it idle at 2k now? mess with the ICV?
            • E30_(1st Musk)_
              • 2008
              well yeah i thought that was the problem, so swaped it for my dads. and its the icv because mine works great on his car...and since then the car idles at 2k...could it be a intake gasket leak? i almost hear no air leaks(than again the engine was r3ved to 2k)
              • catchuk
                • Jan 2008
                • 344
                mines doing the same thing, I just replaced the intake mani gaskets and its not better and what a pain in the ass that was. I was thinking maybe its a bad afm. Im getting an oxygen sensor code and my check engine light comes on at idle. Right before the high idle it started with a rough idle, its almost as if the computer tried to correct its rough idle by running at a higher rpm.
