fuel probem
    fuel probem
    i have no fuel reaching the engine. i jumped the fuel pump relay with no success. replaced fuel pump with a known working one. then found out fuse 11(fuel delivery/fuel pump) has no power what so ever not even with ignition on. what could be causing this?
    Racelands are cheap shit.
    Originally posted by whodwho
    So are r3v members
    dude, this is R3v. there's like 40 project threads, and like 20 FS threads and 100 members ride threads of stupid shit. guaranteed laughs on every page. cut springs, rolled cars at 20mph, fishtank heater core, selling broken stuff, painting cars with paint brush, cheap wings, hella-flush and then there is Vlad, king of the eta M3
    No power to the pump could be a bad fuel pump relay, no timing reference data to the DME, or a problem with the DME. If either of the later are the cause you won't have spark.
    The fuel pump relay is only engaged when the DME sees timing data from a rotating engine.
      ok. i thought i maybe had a faulty reference sensor but i am able to turn on the engine as long as i spray carb cleaner in the intake so that means i have spark. now fuse 11(fuel delivery/fuel pump) has no power what so ever.
      So are r3v members
        If you have spark, the DME has power and timing data. Try replacing the fuel pump relay. If that doesn't help you'll have to trace the wiring (see http://wedophones.com/BMWManualsLead.htm) to find the problem.
          I am just going through my Service Manual (Bentley Publications, 1984-1990 3 series) and there is a mention that ...
          " On 6-cylinder engines only, an additional main relay supplies power to the Motronic control unit and the fuel pump relay "
          Questions:
          1. Does your transfer pump work or have power as it is also powered via the fuel pump relay?
          2. check if you have fault codes on the Motronic
          - http://e30world.com/fuel/BMW-E30-DME...ic-fault-codes
          Regards,
          Ochiix
