misfiring and running like crap!!
  • bimmer_E30
    • 5001
    this all happend this morning...i drove the car friday and saturday and now it's running like crap!
    blowing smoke too sometime..
    Originally posted by e30e
  • chadthestampede
    • Jul 2008
    • 3601
    wut
    Originally posted by bimmer_E30
    i went to start it today and guess what? ran for a bit quite and nice...then my engine started to sound like it was running on one cylinder no power, and blowing blue smoke!
    Friend came over, we did a compression test.........and.....Threw a Rod.
    M20 R.I.P as of today.
    Originally posted by LJ851
    Feedback
      Start with the basics, which would be a smoke test of the intake to locate any intake leaks and running the suite of fuel systems tests in the Bentley. Next would be a new set of plugs (NGK ZGR5A plugs since Bosch W8LCR are NLA) and valve adjustments. I'd also do a compression and leak down test to assess the condition of the head and cylinders.
      I couldn't tell if that rats nest of ignition wires has the Cylinder ID sensor on plug wire 6. But if it doersn't replace that mess with the correct ignition wire set and while you are at it a new distributor cap and rotor.
      If that fails to eliminate the misfire and the compression and leak down numbers are decent, pull the injectors and have them cleaned and flow tested.
      • txtorquemade
        • 1758
        jlevie to the rescue....haha
        But seriously... good advice. I need to do some diagnostics on my car as well. Damn automotive school messed it up. I know.. I know, shouldn't have taken it there to begin with.
        sigpic 1987 325is
        • whodwho
          • Jun 2008
          • 1547
          Sounds like it has a dead hole, I would check the compression / pull the VC and check for a broken rocker.
          My M20 Frankenbuild(s)
          4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
          • chadthestampede
            • Jul 2008
            • 3601
            He sold the car.
            Feedback
            • whodwho
              • Jun 2008
              • 1547
              He sold the car.
              That's one way to fix the problem! :p
              • bimmer_E30
                • 5001
                It's a broken rocker arm ha ha.
