M20 with G240/M42 transmission?
  • SiGmA_X
    • Mar 2006
    • 287
    I am about to embark on the simple task of swapping an M20B25 into my girlfriends 91 318, but have one question. Will the G240 bolt up to the M20, and which clutch/flywheel/starter will I need to run? Can I simply use the G240/M42's original fly/starter/clutch/TOB, or will I need something different? I ask because I'd like to do it as cheap as possible, and not buying a new transmission achieves that.
    Thanks.
    :wgaf:
    PNW BMW Crew ///
    '93 325iS
    '99 528iT
  • shEck3lls0
    • Jan 2011
    • 1154
    looking to do the same thing.... anyone have an answer.
    1989 Alpine 325is 2dr m50 swapped
    Build Thread:
    Current ongoing build. Check it out!
    1991 318is 4dr rallycross
    Rallycross Build Thread.
    1991 Alpine 318is coupe - sold
    • SpecM
      • Oct 2005
      • 4531
      the trans will mate to the motor for sure
      but I'm not sure about the clutch combo
      you can use an m20 fly/pp/clutch on an m42/g240, so I'm sure you can use them here too
      1989 cirrisblau-metallic 325i
      • EN318isPDX
        • Oct 2007
        • 4373
        with e21 TOB
          • 37829
          Driveshaft fitment in the real question at hand.
          Personally I'd use the 260, not like they're hard to find.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
