SETA Question
  • Luis325
    • 3847
    SETA Question
    Quick question in there a way to find out by the block numbers or castings in it if the car is a SETA Block?
    I ask because i just bought a parts car and is a 1988 and has the i harness motronic and I crank refference sensor but the intake manifold has the cold start injector. Also th owner said the car reved to 6,500....??? It has an I cluster.. but the engine was from another 1988 car that was totalled...
    1986 "C2 2.7 Alpina" Sedan
    1987 325ic Black Vert
  • whodwho
    • Jun 2008
    • 1547
    Should be able to tell by the intake manifold shape and/or if it has single valve springs.
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • 37834
      The Super Eta does run the i harness and Motronic system with a different ECU. It does not have a cold start injector though and uses the same ICV as an i car would use. The Super Eta engine uses an i valve cover with an Eta intake manifold.
      You can always get the VIN off the block and see what it comes back as...
      Grover Beach, California
      BimmerHeads.com
      • Luis325
        • 3847
        Where is the vin on the block... there are a few numbers in different places?
        thanks!
        • whodwho
          • Jun 2008
          • 1547
          There is/was a VIN sticker down by where the distributor block off is in the block.
