Transmission output shaft. Please help
  • Matromony
    • 41
    So driving home from work the other day something snapped, at first i thought it was my drive line but after inspection I found it was right after the transmission right past the yolk.
    My e30 is an 86, 325es. After doing some research I think it is the transmission output flange, the 3 bolt one? Also, because it dropped and rubbed I believe it messed up some sort of flex joint. I am new to bmws so i thought I would come to the forums for help.
    Was just wondering if someone would enlighten me to which parts i should order, the driveline looks all in tact besides the fact that its still bolted onto the torn off flange?
    Will someone varify that these are the parts I need?
    http://www.pelicanparts.com/cgi-bin/...5/86),%20M3%20
    Thanks ahead of time.
    -Jesse
  • stumble_t
    • Aug 2009
    • 759
    IDK if this will help part #'s here
    [IMG]http://www.r3vlimited.com/board/
    • accident
      • 7303
      this thread needs pictures.
      Moral of this story?
      • e30Matt
        • 5077
        Yeah, it's hard to tell what's wrong without pictures. Sounds like the flex disc came apart.
        • accident
          • 7303
          that's what i was thinking, but i figured there was no point in saying it if i cant see it
          • SpecM
            • Oct 2005
            • 4531
            sheesh Matt, started posting again?
            1989 cirrisblau-metallic 325i
