M52 crank, b27 rod, b25 piston - m20
  • rvaughnp
    • 136
    crank______m52 - 42mm
    rod________b27 - 130mm
    piston______b25 - 34.2mm
    stack___________206.2mm
    deck____________206.2mm
    gasket____________1.75mm
    ________________207.95mm
    difference________-1.75mm
    OK, could someone help me figure:
    a) what is the CR as is?
    b) what would i have to shave on the block to get it to 9.2CR?
    With my previous posts of not going the shaving route, i found a couple of guys that threw the M52 crank with b27 rods and b25 pistons. They didn't shave the block, but it would be easier to shave the block and get an adjustable cam gear to reset the timing.
    Robert
  • Danny
    • 14217
    ~9:1. Don't shave anything.
    • rvaughnp
      • 136
      Really? 9.2 with a stock gasket? Do you know someone who has done this?
      • Danny
        • 14217
        Do you mean stock gasket?
        Everything I've read in my research has led me to that conclusion.
        • rvaughnp
          • 136
          yeah stock. edited it. thanks. well, that sound like a winner. i'll see what others have to say. I had read where the power dropped off around 6000, but if it works i wouldn't be taking it above that much anyway. that and i might give it to my daughter.
          Thanks for the input.
          Robert
          • felix
            • Apr 2009
            • 18
            • rvaughnp
              • 136
              Awesome, thanks felix. I was expecting to spend a lot of time researching. He seemed to have it down.
              Well... good bye "budget" shave, hello "budget" crank. I'll keep posting.
              Robert
              • rvaughnp
                • 136
                I just reread and a little of the info is off. Not from his calculations just the "quoted" information in the top of the post.
                1) the actual "deck" is 206.2 for the m20.
                2) the "stack height" 1/2 crank throw, rod, piston is 206.7 for the b25 and 206.2 for the 2.7.
                http://www.r3vlimited.com/board/showthread.php?t=157679 has pics of multiple setups but with the stock 2.5 and 2.7 at "deck" height showing the 2.7 even with the deck.
                That being said... i would still gain more air fuel per rotation.
                Robert
                • felix
                  • Apr 2009
                  • 18
                  :) felix=phelix :)
