What do 19lbs do over the stock 17s?
injectors
Stock M20 injectors are 15.24 pph according to the ones I just got flowbenched.
Ich gehöre nicht zur Baader-Meinhof Gruppe
Originally posted by Top GearJust imagine waking up and remembering you're Mexican.
Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
lb/hr.
You NEED a chip (or other kind of tuning/ecu change) if you want to use differant injectors. That is the only way the car will run right.
Anyone who tells you differant is wrong, invite them to provide a dyno with AFR.
19lbs on an otherwist stock car will run really rich, about 10.5AFR. Runs good on e85, thats about it. Significantly down on power from being so rich.
